Bigbird65
Apr 06, 2014Explorer
KevSchofield wrote:
I've refurbished a few old campers and I had a dinette table mount from a 60's Shasta laying around.
I mounted the male side to my camper above where the high pressure propane outlet is.
The mount was well sealed and is backed by 2 inch washers on the inside under my counter area.
Then I laminated a pre-cut 18" x 48" board I got at Lowes for $15..
Just lightly rounded the front corners so they are not sharp.
I installed the female side of the Shasta table mount as well as shelf brackets to the underside of the shelf.
Now I can insert the table in to the mount from the front at an angle and as it lowers to level it locks in to place.
The shelf brackets rest against the side of the camper and provide support as well..
This provides a nice outside space for our Coleman stove with leftover space for a tray of food, seasoning, etc..
I drilled a hole in the table so the propane lead to the stove can come up through.
Kev, I really like your idea. Where would I find the aluminum strips like you used?
