eluwak
Jun 26, 2016Explorer
SoCalDesertRider wrote:
Maybe the trailer is overloaded, or the tires were old and rotted, or cheap Chinese junk? Or maybe you ran over alot of debris in the road? That's alot of tires to blow out in one short trip...
On the engine issue, could be a myriad of things.
On the spark side of things, could be an intermittently bad HEI coil or module on the distributor. Also the coil wire (high voltage side) could be corroded or a bad connection.
On the gas side of things, could be a plugged fuel filter, or a bad sensor in the emmissions system, possibly causing the engine management or injection system to shut down.
If you don't have an OBDII compatible code reader, go to the local auto parts store, buy one and hook it up to the diagnostic port that is usually under the dash and tell us what codes it reads. That will help get things pointed in the right direction at least.
Yeah we figure the tires were dry rotted on the inside. The spare was inside the front compartment. They were 3.5 years old.
In the last 2 years we've put new plugs, wires, fuel filters, tank cleaning, intake manifold gaskets, and water pump (all I can think of right now). The fuel pump is not original, but I don't know how old it is. I'll look into the ODB2 port scanner.
I'll try to respond to others shortly. Heading to the pool for a bit.
44,066 PostsLatest Activity: Apr 16, 2026
