kw_00
Jun 28, 2016Explorer
I don't know if this helps you or not, but I had a problem with my 02 with the 6.0.. We would loose power puling and have misfires, nobody could figure this out except myself. The dealer wanted to replace the entire fuse box, and the independent shop I used replaced the fuel pump, and bought all new injectors and replaced them. None fixed the issue. The truck would run perfect then all of a sudden it would start misfiring, throw a code and lose power. I asked both mechanics if it was the CPK sensor. Both said no cause the code was not showing it. Well after getting stuck alongside the road with the same problems, I replaced it myself and the truck started right up. Had the relearn process done and never had a problem since prior trading it for my newer truck. Good luck and keep us posted. And oh BTW they replaced my fuel pump twice thinking it was the issue...... but like I said it was not.
44,066 PostsLatest Activity: Apr 16, 2026
