Jarlaxle
Jul 03, 2016Explorer II
eluwak wrote:dodge guy wrote:
Can't comment on the trailer. My only question is how old were the tires?
On the Burb, it sounds like you've got a fuel pump failing! On GM's a common fuel pump fail symptom is no power, lack of power, no acceleration and stumbling when you give it gas. It will feel as though you are running out of gas!
How many miles on the Burb, and have you ever replaced the fuel pump, or for that matter the fuel filter!!! (Has it ever been replaced?)
The fuel pump is newer, but not sure how new. I've less than 1000 gallons through the new filter I had put in. I see a general trend saying it might be the pump, so it's a place to start.
Can you CHECK the filter? I wonder if you got a tank of bad fuel.
44,066 PostsLatest Activity: Apr 16, 2026
