crcr
Mar 24, 2015Explorer
crcr wrote:Mark Kovalsky wrote:
... snip
... If you want to cool the transmission, you need a better aux trans cooler. I'm not familiar with the Dodge cooler, but I'll bet you could replace it with a better one and do a MUCH better job of cooling the transmission.
The OEM trans cooler in the 3rd Gen 5.9 Ram is already quite large. See pic below of it revealed with the AC condenser hoisted up out of the way.
The pic above I provided earlier isn't my truck, I pulled it off the Cummins forum. But the thermostat built into the OEM trans cooler that many have taken out and cleaned and thus gotten lower trans temps, is at the right end of that built in line running across the top of the trans cooler, right above the rachet you see hanging there.
44,059 PostsLatest Activity: Mar 17, 2026
