Hi,
It was sold as a 30 amp unit. Why would there be any recourse? Many homes have only a 100 amp service and there is rather rarely a problem with the main breaker tripping. In fact, I've never had one trip, nor do I know anyone who has had a problem.
It is rare that all the devices in an RV will be "on" at the same time.
There ARE some things you can do that will help you out, but they require changes to the RV.
Here are some ideas in a random order.
Add an auxiliary 20 amp shore power cord. If there is space in the power distribution center, add a female outlet and put a plug on the end of the items you wish to run on this "extra" service. I chose my water heater.
Add a double pole double throw switch and power the water heater or microwave. One position powers the micro, the other the water heater. The water will remain hot enough for a warm shower for about 8 hours. (I did not choose to do this, but others have.)
I added a second auxiliary cord which I use to power various items. Again I used simple male and female plugs, so I can switch back to the OEM configuration in about 20 seconds.
I have a good size inverter @ 2500 watts. I added a dedicated inverter outlet in the kitchen. This lets me use lots of power on a short term basis--and the converter will recharge the battery bank over time. I leave my inverter running when ever I am in the RV.
I also have a "break out box" which lets me use 50 amps at the pedestal if it is available. It gives me a 30 amp (with breaker), and two 20 amp (with breakers) outlets.
These modifications allow me to run 30 amps OEM, 20 amps aux, 15 amps aux, and 22 amps from the inverter outlets, all at the same time.
If there are only 15 amp circuits available I still have plenty of power for my needs, so long as there are three circuits of shore power available.
If there is a single 15 amp circuit available. I can run my water heater, and converter, while powering the rest of the RV from the inverter.
If I am boondocking I'm limited to the 22 amps the inverter will provide. But that is pretty close to the 24 amps that the OEM should be run at to keep to the 80% of capacity guide line.
In a pinch I can add a further 2 or 3 amps using a second 400 inverter.
I hope these ideas help you out.
retcsgt wrote:
My TT has 30 amp service now, just don't understand why they place all these appliances in it if main circuit breaker isn't going to allow them to work at same time. Is there any recourse from my point against the dealership that sold me the unit?
