thegrindstaffs wrote:
We have a 2010 268RL that was purchased about 6 months ago. We've finally fixed a most of the little things that were broken, added a 2nd 12v battery, led lights, one MaxxAir vent, and cleaned it up. Now that I feel like I have made some headway on the camper I wanted to address the maintenance side of things. Everything works just fine as far as I know. We've used it a handful of times since we got it, but I have nothing to compare it to since it's our first TT. I read about bearings and axles and flipping tires, etc. but honestly I have no idea what that means and if it's necessary for someone like me who will camp for 20 nights a year and take one 1,000 mile trip a year. What do you guys recommend that I put on my list to do? I am willing and able to do the work. Thank you guys and gals for all your help. The info on this site has been a huge help.
1. check the age of the tires-- first 2 numbers represent the week and the last 2 numbers represent the year the tire was mfg. I buy new tires every 41/2 to max of 5yrs. regardless of how many miles I put on them or how they look. Tires are rated for load capacity-- C D E G, the higher the letter the greater capacity the tires will support. I use the highest rated LT (light truck) tire that will fit on my 5th. wheel.
2. I take my trailer to my local Tire shop "Les Schwab" to have the bearings packed and inspected for wear. If a bearing needs replacing, or brakes need replacing, they have the parts right there. Inflate the tires to the max PSI as indicated on the side of the tire.
3. Check the age of your batteries, the age of the batteries can be found by looking for the punched out numbers or numbers embossed on the tip. Make sure the post are clean, free of any corrosionm filled with distilled h20. Any battery 5 yrs. or older, I replace them.
4. replace the air filter and fuel filter as indicated by the mfg. on a regular basis.
5. Have all your fan belts checked for any wear or cracks.
6. Have your radiator checked to see if your anti freeze needs replacing.
7. Buy a Emergency Road Side Service policy. I don't recommend AAA because their services vary depending on where you are located. i.e county to county , state to state etc.
8. Hit the RV road and enjoy!
