Deb_and_Ed_M
Nov 20, 2014Explorer II
WOOHOO!! The Unicorn has arrived!!!
Brian Hayward from Palomino customer service (my hero!) forwarded the magical code for 4-pin round plugs (keep in mind this is for a 1995 Bronco 1200/no taillights - but I'd have to assume it will work for similar Bronco models through the years?) and I'm posting it in case it will help someone else:
Red wire = battery positive to the converter
Green wire = is for running lights
Grey wire is for battery positive to refrigerator
White wire is the ground.
All I have to do is pull the plug to see which wire goes to each pin; and then wire the camper and truck plugs the same. Easy-peasy :-)
As an aside - I've had great customer service from Palomino - they will be first on my list if I ever need a newer/cuter/fancier/larger camper.
