Dick_B
Aug 26, 2015Explorer
X2 with GaryWT comments. As I have opined previously, unless you are on a concrete pad there will be movement due to the ground (gravel/grass) movement; even a little bit. I'm guessing that a 1/16 inch movement between the jack and the ground could result in movement of the trailer several times that amount.
44,066 PostsLatest Activity: Apr 10, 2026
