Doug33
Aug 29, 2015Explorer
Your susceptibility to movement is enhanced by how high your TT sits off the ground. Ours is very high, so it is very difficult to block with jacks, etc.
Also, our axles are very spread out (more than 18 inches between tires) so use of x-chicks is not practical. I do place two scissor jacks mid frame which helps some with bouncing. However, if you are sitting on the throne in the back of the TT and someone is moving around in the front bedroom, you are going to feel it.
44,066 PostsLatest Activity: Apr 10, 2026
