work2much
Aug 29, 2017Explorer
tad94564 wrote:work2much wrote:
We did spring for the 32 inch TV. HOST unlike other manufacturers doesn't use a 12v TV. They use name brand 120v and add a inverter to power it. I liked that. No TV in bedroom.
Either have them install one of these, or do it yourself when you get it:
Xantrex 8080915 PROwatt SW Auto Transfer Switch
That way, when your on shore power, the TV will work without having to diddle with the inverter.
Thanks for the link. That looks like a good way to go.
For the most part shore power will be inverted battery power. We haven't plugged in anywhere in over year on the road. One goal of the new camper is to remain off the electrical grid.
I like the idea of having a quality 120v tv that is run through a dedicated low watt inverter that we can leave on (or switch off) as opposed to plugging it in to a 120v receptacle that we would need to turn on our main high watt inverter. Host includes the inverter so I will see what that is and go from there. I am also looking at small inverts to run the fridge on 110 vs propane.
44,070 PostsLatest Activity: Aug 07, 2026
