- DutchmenSportExplorerSome do not have manual cranks. Mine has a motor only with no manual cranks. In order to open my slides manually I have to attach a flexible socket wrench on the end of a drill to the end of the motor and use the drill to turn the motor in order to retract the slides. In order to access the motors I have to get underneath the camper and remove the colorplast. So not all slides are the same. What you can do is go out to YouTube video and put in the search window your make and model camper and the word slides or manual slides and see what videos come up which will explain how to do it.
- drsteveExplorerProbably the same as the crank that raises and lowers the stabilizers.
- TerryallanExplorer IIYou also need to be sure what type slide you have. Mine has no hand crank. sould mine quit, and I pray it NEVER does. I have to disengage the electric motors and push it in.
- MFLNomad IIIf you are looking for the place to attach crank handle, it is often accessed from the other side of camper, from the slide.
Jerry
44,066 PostsLatest Activity: Jul 25, 2018
