Fordlover
Mar 18, 2015Explorer
blofgren wrote:
OK, I'm going to go against the grain here and state that my preference is a manual transmission, which my last 3 trucks have been. They cost less, generate WAY less heat especially under load, are extremely reliable, and are a snap to drive for an experienced driver. I drive a 2012 F-150 for a work vehicle and as much as I will admit that the newer automatics are better than they used to be, they are still not as good as a manual. I also can't help but think that these transmissions will cost a fortune in the future to rebuild/repair when the time comes, which it will especially when towing heavy.
With all due respect to those who state that they are difficult to get a heavy load moving, back a trailer into a campsite, etc. I can't help but think that they have not driven a manual transmission mated to a modern diesel with plenty of low end torque. My Cummins/6 speed manual transmission has the zero throttle launch feature which means put the transmission in the PROPER gear (not too high, especially under heavy load), and easily let the clutch out. This is easily accomplished with any heavy load on any hill and the truck does not even snort. The Cummins/manual transmission combo was a match made in heaven!
In regards to driving in heavy traffic, as long as I am watching traffic ahead and using the exhaust brake in full on mode, I can easily drop down to 15 mph in 5th gear using the exhaust brake and pull out of it without downshifting. If you are a race to each light and hit the brakes kind of driver, this method will not work for you!
Yes, the Cummins is derated on paper with the manual transmission. I drove Cummins equipped trucks with both the manual and automatic transmissions and the manual transmission did not feel any more sluggish, perhaps because of the power absorbed by the automatic. In any case, I am not at all unhappy with the power of my truck and even if I was a programmer will easily fix that when my warranty is up.
And lastly, I'm not sure why some are saying the manual transmissions are gone when Ram still offers the Cummins with a manual.
Just my 2 cents worth.
I'm with you but for much different reasons. Nothing is more irritating to be off throttle mid corner for two seconds, have the automatic upshift, then I get back in the throttle while tracking out once I'm past the apex just to have the auto shift back down a gear. Too much shifting and ALWAYS at the wrong time. It can easily upset the balance of the car which is critically important when driving on the edge.
As long as my brain still functions and I have the option, I'll choose the Manual transmission, at least for my 'fun car'. I gave up on truck manuals in 2002, because it wasn't an option with the V8 in the Explorer.
44,071 PostsLatest Activity: Aug 16, 2026
