BRP wrote:
Thanks everyone, sorry for posting this question twice, didn't think the first one went through. I have a Ford F-250 Supercab SRW 4x2 with (according to the code on the door) a 3:73 axle but it has a dash next to what should be the 5th wheel tow rate so either I can't or it's the one above it showing 16,000 LBS. therefor my confusion.
Again Thanks
Since you say you have a 3:73 axle, you must have the 6.2L. If you have an 8' box, you max 5th wheel is 12,900. If you have the 6 3/4, your rating is 13,000. These numbers are for 2017+.
If you have a 2011-2016, the ratings are around 500lbs less.
