spud1957
Apr 02, 2016Explorer
March results
Good results for all except Tundra.
http://news.pickuptrucks.com/2016/04/best-selling-pickup-trucks-march-2016.html
Me Again wrote:Cummins12V98 wrote:
"Again the RGAWR is the most limiting number with a 5th wheel. "
The above is rarely considered. Most of the time all people look is the spec that says I can tow XX,XXX and think they are good to go up to that number.
I said nothing about people looking at it, only that is was the most limiting number with a 5th wheel.
Now I will say it. People should be looking at this number!!!!
Chris
travelnutz wrote:
Ford has always only makes/sells/sold ONE designation of trucks and ALL are called F-series for over 60 years now. 150 thru 750 model lines generally and includes the Ranger line. Even had a 100 series full size truck in the series for many years too. Look it up and do your research!
GM makes/sells/sold 4 lines of trucks in various model series presently and has made up to 7+ at one time. Presently is the production of the Silverado, Sierra, Colorado, and Canyon and soon will be adding the 450 and 550 lines again so it will be 6 lines then. Past lines were these 6 plus the Avalanche and don't forget the Luv trucks! All are available/sold in the pickup version also.
A bushel of apples is a bushel of apples whether all are Northern Spies or are a combination of 20+ different lines or variety names! Still apples!
What's so hard to understand about recorded documented/verified facts?
45Ricochet wrote:
The "F series Ford" is for all Ford trucks 150-250-350-450-550-650-750 not just a F150 truck.
I think another headache has sprung up guys :B
blt2ski wrote:
For those interested, some of the commercial truck rags will show the class 3 thru6 or 7-8 trucks sales by manufacture. I personally have not seen a break out of class 3 dw vs sw. Other than for most years in the past, a sw 25 series being as the gvwr was below 10000 lbs, it was really a DOT hd class 2 truck, or what I call a HD 3/4 ton!
With many of the sw35's being over 10K in gvwr, they do truly fall into the DOT class 3 trucks or 1 tons. Again, not sure you will get or find a break out somewhere.
Marty
