Louisi's avatar
Louisi
Match truck and camper
We have been sailors for many years and are now interested in truck camping. We are looking at a Lance 855s and a Ford 250 supercab short bed with a camper package. Although we would prefer a crew cab, the super cab fits in our garage and the crew cab does not. We are concerned that since the cab is shorter it may cause some instability in the truck or perhaps another problem we have not thought of. We would appreciate comments on this match as well as any comments on the Lance 855s itself. Thanks
  • Bedlam wrote:
    To carry 7000 lbs level on the rear of my truck only required upper and lower StableLoads:
    My apologies for the thread hijack, but can you explain what I'm seeing there. Is that a heavier leaf sitting on top of the leaf that engages with the Stableload? Do they separate as your springs compress?
  • A typical F250 does not have the upper overload spring and perches with pads. If you have the camper package or a F350 the upper spring will be there but requires over 3" of sag before it is engaged. The front half of the spring will engage the pad before the rear to give you a more progressive spring rate when loaded. Using the taller upper StableLoad pads engages the upper overload in 1/2" to 1", so it uses your overload suspension sooner (like a preload setting on a motorcycle shock).
    The lower overload is on both the F250 and F350. Until you compress the arch out of your spring pack, this spring does little. The lower StableLoad wedges are actually three wedge plates bolted together. This allows the lower overload spring to engage sooner and preserve more of the main spring pack arch. Based on the number of plates you use, you are also changing the preload on the lower overload spring. When this lower spring is engaged while you are unloaded, it results in a very harsh ride. Torklift created the wedges with a swing out hinge so you can disable your lower preload wedge when not carrying a load.
    The photo you saw previously is the forward half of the spring and you can see the stabilizer bar end. This what the rear half looks like:
    BTW: These photos were taken with my 4000 lb TC loaded, but only 5 PSI in the air bags and no trailer hitched up.
  • Thanks, but I'm specifically curious about the part of the upper overload spring that doesn't contact the Stableload in the pic I copied. It looks to me like that spring would be pushing down, not up. I'm actually thinking it might be a way to reduce sway.
  • I had to look twice but me thinks it is an optical illusion... there is only 1 top overload spring.
  • The top spring is a single metal leaf. As the main spring pack compresses, the upper overload spring is pushed against the upper perches and resists further upper movement once it contacts the pads. I found that the upper StableLoad pads do more to reduce sag and the lower StableLoad wedges do more to reduce sway.
    My Ram 5500 is set up the same way, but has two upper leaf springs.
    You're right. I zoomed in and it's the streak in the dust my eyes were seeing as the end of a shorter leaf. Never mind...
