rexlion
Jul 17, 2014Explorer
Chances are good that the longer model could be too heavy on the hitch once you load up the trailer. Especially if the fresh water tank is up front (I don't know if it is). LP, battery, water and gear add more than one would expect to the hitch weight. But check on the actual hitch weight allowable with the Grand Cherokee. Because I thought they all get the same class IV receiver regardless of engine choice, and if so, your allowable hitch weight may be more even though the tow rating is still only 6200. You will need a WD hitch, of course.
44,027 PostsLatest Activity: Mar 05, 2025
