Ron_Gratz
Jul 17, 2014Explorer
Campfire Time wrote:The governing factor for the OP's choice of trailer is likely to be tongue weight.
---I agree, most of us don't load the trailer to its GVWR. However if you use GVWR in your calculations and you don't load your trailer to its max, you have some wiggle room.
Are you saying the OP should base his decision on assuming the loaded tongue weight will be 15% of the trailer's GVWR?
Does the trailer's cargo carrying capacity enter into your recommendation,
or do you assume the trailer will be loaded to its GVWR regardless of CCC?
Ron
44,027 PostsLatest Activity: Mar 05, 2025
