bodomalo's avatar
bodomalo
Max. Trailer length - NP and state parks
I know this topic has been discusses maybe many times before, but I have a particular questions about those "lengths" trailer vs. 5th wheel.
Very often campgrounds have a max length for RV and for trailers
Example:
Max. RV length: 27"
Max. Trailer length: 24"
So the campsite itself might be much longer, as you need to park a trailer and a towing vehicle there (I would say there have to be campsites which are at least 42-45" long in total)
The limitation is very often the road to the campsite itself or a tight and narrow road on the campsite (not so easy to turn a trailer backwards into that spot).
Now my question: Is there a difference in the ability to drive backwards with a normal trailer compared to a 5th wheel trailer?
In total a 24" trailer + car might be a few feet longer than a
24" 5th wheel on a Pickup Truck (I would say 4-6 feet at least?)
So if there is a trailer limit of 24", would you say that you can still get into that campsite with a (example) 26" 5th wheel? Or doesn't it make any difference when trying to get into a spot?
  • To answer the backing question, a bumper pull trailer will start to turn quicker, when backing, due to being hooked to the very rear of the tow vehicle. A FW turns much slower when starting to back, but turns very quickly, once the angle starts to make a major change.
    I never have much problem with SP campsites being too short for my 31' FW. I have found the FW height to be the bigger problem. Most SPs have a lot of trees, with low hanging branches.
    Unless you get one of the really small FWs, most will be closer to 30 feet or more, overall length. There are not many newer 24' FWs available anymore.
    Jerry
