valhalla360 wrote:
mr61impala wrote:
APT wrote:
The general feedback for people towing over 8000 pounds loaded with half tons is not positive. How much is your as equipped payload and receiver rating? 8000 pounds loaded means 1000-1200 pounds of tongue weight. How much stuff/people do you put in the vehicle when towing? That Tire and Loading sticker will likely be your limit well under 11,000 pounds for a TT.
Just the two of us in the truck and we have always packed with weight in mind.
This truck came from the factory with a class 4 hitch which I believe is rated up to #10,000.
The larger trailers under consideration have the following specs:
1). UVW of #7050 and hitch weight of #710,
2), UVW of #6500 and hitch weight of #735.
Once loaded those trailers are likely in the 8000-9000lb range with 1000-1200lb hitch weight. (hence the suggestion to look at GVWR rather than UVW as a first pass)
So if your payload rating is 1800lb, that leaves you 600-800lb after hitching the trailer. You and the misses weight comes off that and then anything bolted onto the truck and any cargo...It can be done but if you want to stay within the payload rating, you need to be really firm about loading things in the truck.
This is why I suggested 7000-7500lb (GVWR). That brings the hitch weight down and gives you some breathing room on truck payload.
The pretty much all come with a class 4 hitch...it's rating rarely is a consideration.
Thanks for all the great information! Just went to two trailer websites. The original trailer we bought the truck to pull was listed as #5700 last year, but is now listed as #6000 UVW; the #7000 GVRW, and #730 hitch weight are unchanged. The other trailer is still listed at #6100 with a GVWR of #7700, and a hitch weight of #715. The main difference I see is it has larger tires/wheels, 15" vs 14", and the trailer with larger tires is 3" taller. One can carry #1000 of gear, the other #1600. I like the reserve capacity even though we would never use it. Wouldn't these be very similar in the real world, assuming the same amount of gear loaded into each? Apples and oranges I know.
