MitchF150 wrote:
Please show me your work on that math that I am 3,000 over weight on my combo Terry?
I do include the TW of the trailer on the trucks payload too.... I've been around the block a few times and here longer than you have been... ha, ha... Mitch
remember. I said if you load both to max. And IF your 11,300 is the GCVWR. Which I admit seems pretty low. I could have read it wrong. If it is not. Then my figures are wrong. I been wrong before.
Your truck if loaded to max is 7700lb. your trailer if loaded to max is 7000lb. that is 14,700lbs. Your max GCVWR, is 11,300. According to you post. Unless I miss read it.
So together your TT and TV weigh in at 14,700lb subtract the GCVWR of 11,300 from that, and you have 3,400lb that the truck is over the GCVWR. Like i said. If that is not the GCVWR. Then my figures are not correct.
