Groover wrote:
Grit dog wrote:
That drivetrain is bulletproof and will rip the hitch off of most any TT. It’ll have similar power to all the new 3/4 ton gassers.
Only downfall IMO is the relatively compliant rear coil spring suspension which can be overcome with an appropriate wdh and/or a set of airbags.
I’ve hooked some heavier trailers to a rental Ram 1500. (I’m in construction, so “weights “ are relative. If it ain’t on the bump stops it’s good enough).
The rear is a little squishy-er than leaf spring “normal” half tons. Not including the heavy payload F150.
I wouldn’t blink an eye at an 8000lb TT.
The OP said that he has every available towing option but I don't see where he said one way or the other on coil springs vs airbags. If he has airbags that might solve the squishy problem.
Good point. Idk what the 4 way air is good for payload wise but would presume it would level up about any TT with a wdh, at a minimum.
