JIMNLIN
Jan 10, 2014Explorer III
JJBIRISH wrote:
Changing to LT tires is outside the scope of the op thread… but I will say while those that have made the change are convinced and happy with their choice…
I still fail to find many manufactures jumping on this band wagon… including Michelin…
QUESTION:
I want to put Michelin LT tires of sufficient size and load capacity on my trailer but I am concerned about some of the warranty language…
Can I use properly size and rated Michelin LT tires on my trailer???
Thank you for your time in this matter…
ANSWER:
Most trailer tires are ST type tires that carry more weight and are designed for trailers.
If the trailer maker specifies an ST type tire then using an LT type tire would be a misapplication and would void the warranty.
If the trailer maker specifies an LT type tire would be approved then and only then would the LT tire be used.
If you have other questions or concerns feel free to give us a call at the number listed below.
We appreciate your business and thank you for choosing Michelin.
Depending on ones agenda a loaded question on direct tire replacement backs an tire mfg into the liability corner as has been explained many times or if ones agenda is finding which tire any tire maker recommends for a trailer simply do as this guy did with his question and answer from Michelin.
Answer from Michelin;
Michelin responce
Posted: 12/14/12 12:14am Link | Quote | Print | Notify Moderator
I sent an email to Michelin for a response regarding using Michelin XPS ribs on my 5th wheel. Here is the question and their response:
Thank you for your email. We welcome the opportunity to serve you.
Due to recent high email volume and some technical issues that we have experienced, please accept our apology for the delay in this response. Your interest in Michelin is certainly appreciated.
In regards to the email you sent stating:
I have a 2006 Montana 5th wheel Trailer that has two 6,000 lb Dexter axles and 4 deluxe aluminum Rims each rated at 3,042 lbs. I would like to install your Michelin XPS® Rib™ LT235/85 R16/E's on this 5th wheel. Will the tires be fully waranteed in this application?
Answer..---------------------------------------------------------------------
We appreciate your request for information regarding the Michelin XPS Rib. The XPS Rib, size LT235/85R16/E, part number 13080 would be a good fitment for your 5th wheel. The tire carries 3042Lbs at 80-psi max pressure. For best pressure recommendation, run at maximum pressure until you can weigh your axles either call or reply to this email for a pressure recommendation.
It is a good application, so there are no warranty issues. Your tires are covered under applicable warranty.
It is our goal to ensure that your issue has been resolved or your question answered to your satisfaction. If we can assist you further, please respond to this email or call us at 1-800-642-4354 (toll free) between 8:00AM and 8:00PM Eastern Time Monday through Friday or between 8:30AM and 4:30PM Eastern Time on Saturday.
Sincerely,
Diana
Consumer Care Department
Certified Michelin Product Expert
PS: It's important that you get all the safety-related materials that come with the purchase of new Michelin passenger and light truck tires. If you did not receive a warranty book, you can download one at www.michelin.com/warranty/. If you did not register your tires, please take a moment to do so at www.michelin.com. Registering your tires is easy and takes just a minute.
44,068 PostsLatest Activity: Jun 17, 2026
