RobertRyan
Jul 19, 2017Explorer
ShinerBock wrote:RobertRyan wrote:
Needs to be heavier and carry a lot more Off Road.New Mercedes is rated at 1100kg =2420lb Ford Ranger Wildtrack 4,960lb about the same kerb weight as the 2.7 F150
The ZR2 is not made to carry a lot and it weighs between 4,700-5,000 lbs depending on the engine. The diesel engine will put it closer to 5,000 lbs just like the Wildtrack. Unlike Australia, we have other bigger pick up trucks for that purpose of carrying heavier loads and this is mainly a niche vehilce. Also, as I said earlier our regulations limit class 1 vehicles to 6,000 GVWR so even if that MB was sold in the US, it would not have nearly that amount of payload rating. Take the Wildtrack you just stated, since it weighs 4,960 lbs like you stated, and it's max allowable GVWR is 6,000 lb, then its payload would be (6,000-4,960) 1,040 lbs.
WildTrack, has a payload of 980kg =2100lb. Mercedes XClass 1100kg =2460lb.
Colorado ZR 2 a payload of 1100lb and Gas engine 5000lbs towing.. GM gives 5000lb towing maximum for the 2.8 Diesel
X Class will be a heavy beast with a 2460lb payload.
