NinerBikes
Oct 09, 2014Explorer
Proteus wrote:
Thanks, just for an update on this, we decided to rent for a while, and took a Nash 25c (not ideal) from Seattle all the way to Yellowstone and Glacier. The trailer loaded was about 6200lbs, so within the 7200lb tow rating, and we used an equalizer 4 points wd hitch and prodigy bc. We did everything from broken roads, to long stretches on the plains with 40mph crosswinds, and did some nice long steep sections, including the continental divide.
So, this combo worked, but it wouldn't recommend it . The Nash rides high, isn't that aerodynamic and has a bouncier off-road suspension. The weight itself was fine..the diesel has plenty of torque (455) so pulling was never an issue, and was great for engine braking too. Going steep uphill on the long I-90 stretch over the divide, the little engine was working hard I had to slow to 50mph in sections (normally kept at 60-65). Trailer sway in crosswinds was noticeable, but the trailer mode in the AWD corrected everything nicely. Rain, thunderstorms, no problem, just slowed down some.
Oh, and I averaged about 13mpg towing (vs my normal 30 highway, not too shabby). I would NOT do this with a gas model. The diesel makes a huge difference. Note that the Jeep Grand Cherokee is basically the same thing. I have to say, was pretty funny seeing the occasional guy in pickup truck gasp as we passed them :)
Bottom line, I'd say a 4500-5000lb dry trailer is fine. I would make sure it has a proper (not bouncy leaf spring) suspension, and rides lower to the ground. It's a modern SUV and needs a modern trailer to go with. Airstream would also be great, but they're not family friendly (we need a bunkhouse.
My TV is a 2013 VW Touareg TDI Sport. 240 HP, 406 ft lbs. Tongue weight 300 dry on a 21 foot 7.5 ft wide TT that weighs in at 3700 dry. Bought the Touareg with factory hitch, 7700 lbs, limited by the unibody construction on all engines. Tongue weight is 770 lbs, max.
With propane, battery, etc, I run a 600# Equalizer Hitch. I probably have 300 to 400 lbs on board the trailer.
At this point, in 2 years, I have 16000 miles on it. I will not trailer if cross winds are much over 25 mph, I pull over. No equalizer hitch will help you in a cross wind if a big rig blows by you at 80 mph while you are doing 55... 21 foot of wind sail leaves you with sweaty hands and white knuckler moments, too much hinge effect at the trailer hitch point with the SUV having a short wheel base. Allows the trailer in a cross wind to have a lot of leverage at the pivot point, where the two vehicles are joined.
Out west, there is no way I'd go much over 21 to 23 or 24 feet, with a 5000 # Touareg, Cayenne, or Q7.
Trailer is a Palomino Gazelle G21.
3.0 Liter diesel at 55 -58 MPH and 8 speed transmission averages 16.5 to 19 MPG. I seem to manage to find some tailwinds most of the time from Los Angeles to Yellowstone.
I do slow down a bit going up the steeper grades in CA, NV, UT,ID and MT. Retired, no rush, don't believe in pushing my motor hard going up hill doing a lot of work. I try to keep fuel consumption at no more than 4 to 4.5 gals per hour of diesel fuel being burned when going up hill. Function of speedometer, and instantaneous MPG in the dash keeps me from running hot. Don't burn the fuel fast if you want the heat dissapaition spread over a longer time.
