Proteus's avatar
Proteus
Mercedes ML350 Bluetec - How big a TT can I tow?
New to this and need some advice. I have an ML350BTC as a tow vehicle. Plenty of power (455 ftlbs), and it has a 7200lb tow rating. I'm looking for a lightweight 25-28ft travel trailer with bunks (something like a surveyor sport, or passport). There is a huge difference in weight and construction..the ones I'm looking at come in right at 5000-5200lbs (delivered weight, from door sticker)
Question is, I've visited a number of RV dealers so far that seem to think you need you need a traditional truck to tow (although one changes his mind when I pointed out this was basically a fancy Jeep Grand Cherokee)
GVWR is 6504, RAWR - 3638, FAWR 3197, curb weight 5109.
This leaves me with a payload of #1395 (more than a "half ton" in truck speak). Tires are rated over 2100lbs each, so no issues there.
My hitch rating is low at 575lbs, since European standard is 8% on the hitch, not 15% like here. From what I understand, a good WD system will take care of that (locally, equalizer "four points" seems to be popular). Per the dealer, the MB has trailer towing software that automatically detects and corrects for sway.
So question is this: Can I safely tow something like:
Keystone Passport 2650BH (4950 dry, 470 hitch),
Coachman Captiva 270RS (4600 dry, 740 hitch, the WD should help here?)
or even a Surveyor cadet SC-280(4700, 504 hitch).
I know in Europe, people tow large boats and caravans with these, and even here in the US, the Airstream crowd tow the heavy 25-28ft models (and per youtube, apparently even the 7500lb 30fter!). At the same time though, there seems to be some great difference of opinion out there.
  • There certainly is a great difference of opinion on this topic; get ready, you are gonna hear from 'em all.
    I have a Jeep Liberty CRD, 335 ft-lbs torque, rated to tow 5,000 lbs. My TT is 21 feet, 5,000 lbs gross/3650 dry weight. And based on my experiences with this set up, I'd say you'll be fine with the Captiva or the Surveyer. The Keystone leaves a little less cargo capacity than I'd like to see, but it might be fine. I think your tongue weight capacity is too low, however. You might have to do something about that.
    And yes, I'm sure there will be folks horrified at my rig, just as they will be at your proposed ones.
