Dakota98
Dec 04, 2014Explorer
Dog Trainer :
I think you make a very valid point. Doesn't really make sense, does it?
For the most part, I believe it has more to do with a manufacturers "limits of Liability"
All components "installed by the manufacturer" at the time of build enter into that arena.
Anything added as "aftermarket" are at the owners option & liability.
A simple example, my truck is rated at 5320# GVWR "as built". The front & rear axles, combined are at 6166# & those figures are based upon the weakest ling of the entire suspension system. I have added helper springs and changed to 108 rated tires only. When loaded with my ATV in the back & hooked to the TT (550# tongue weight), a full tank of gas, & with me in the drivers seat I'm at 5650# (Cat Scales). It handles like a dream.
Another thing & I hesitate to mention this because the "weight police" will send the Sheriff to my door.
My truck "as built" has two ratings for GCWR.
The first is 9,200# with 3.55 gears (which is what I have)
The second is 10,500# with 3.92 gears
I have a WDH & anti-sway. My rig never flinches when a semi passes me & I never go over 60mph.
I'm at 10,620#, TT loaded - NO water. I put water on board when I'm a few miles from destination.
I have had absolutely no issues with handling. NONE
I realize this is putting a strain on the transmission, yes, I have a cooler. When pulling I disengage the OD.
44,056 PostsLatest Activity: Jan 22, 2026
