lincolnmatthews
Nov 28, 2017Explorer
Thanks you guys! I do have the steering brace from BD. Talked to Schwab this week,as I expected it should have the front end aligned with the camper on (as this camper is always on the truck). It sounds like it will have to go on the big truck rack because of the height & width for the some of $200.00 min. oh well I don't care at this point.
I think there's to much play in neutral on the steering wheel (rblt Redhead gear box about a yr ago, so I'll tighten that up a little, & will have my indy check out the front end before it goes into Schwab to check out (just for another opinion). I do think after the replies here that its not my tires but needs a front end alignment. I will let you know after I get this done, (in about 2 months or so) Thanks again!
44,056 PostsLatest Activity: May 04, 2014
