covered_wagon
Dec 24, 2017Explorer
Tightening up the set screw on top of the steering box gets rid of some side to side play on the Dodge steering wheel. I did mine yesterday and it made mine much nicer.
The DSS that supports the steering bearings helps keep it from wearing out with the side to side movement that is so hard on the box bearings. Plus ties across frame to frame with cross member right where the box is and stops that Dodge frame flex so common. Helped mine a lot even when just 30,000 on the clock.
44,055 PostsLatest Activity: Dec 23, 2025
