prichardson wrote:
No need to remove the battery and LP tanks for storage.
I disagree !
First, most storage lots recommend that you take your battery home, simply because it is too easy to steal. LP tanks, not so much.
OP lives in AZ. Lead acid batteries do not do well in hot temps
(ever notice that almost all new car batteries now have an insulation sleeve ?). Yes, it is a hassle to remove and replace the battery each time, but if you don't it will shorten its life. A quick rinse with the garden hose each time is also a good idea.
