Microlite_Mike
Jul 23, 2022Explorer II
RabbitBison wrote:
Can’t find the port to attach manual crank. Micro Minnie 2019, 2108DS. SOME SAY IT SHOULD BE OPPOSITE SLIDE, In big frame. Help, please.
On through frame slide actuators, the manual operating shaft may or may not extend fully through the frame from the gearbox. Some have a short extension with a hex head that allows the slide to be operated with a socket and ratchet. Others have an adapter with a length of shaft attached that extends through the frame and can be accessed with a crank handle without having to get under the trailer.
When slide is out, locate the actuator (round tube that goes back into the frame. The manual operator "port" is on the end farthest away from the slide itself.
On mine it's hidden behind the folding stairs.
