naturist
Aug 12, 2014Nomad II
I believe you will find that your generator has an automatic overload protection, which will cut the power off completely if the load exceeds its capacity. So as long as it doesn't kick off on you, the generator will not be damaged.
I, too, think that it is likely that your converter is drawing enough to cause the dimming of the lights when you run the microwave. I'd test that theory by making sure the battery was fully charged OR turning off the battery cutoff switch when attempting to run the microwave.
