Danford50 wrote:
I check the microwave by plug it into another outlet, i also check the gfi outlets and they all work, i check the outlet the microwave was plug into by pluging my phone charger into it and it would not charge my phone.
I'd next disconnect from shore power, remove receptacle and check connections. With the receptacle out, but clear of anything in the cabinet, turn shore power on. Check all connections on the side of receptacle with tester. If there is power, replace receptacle. If no power, problem is probably at your power center
Good luck.
