Danford50 wrote:
Ok i have replace the breaker and still no power to the outlet, i went to camping world to get another outlet but they did not have one, so i guess i check around and try to find one before i go and order one from cw.have anyone ever had to replace their microwave outlet? and if so did you go back with the same type as the original, or did you use one like you would find in your home?
You can usually replace a RV, flush-mount receptacle with a single gang, shallow, old-work plastic box. A new, standard duplex receptacle can be installed in that box.
