Grit_dog
Aug 03, 2022Trailblazer
SoonDockin wrote:
The F450 is super capable. Maybe I should look for different tires to absorb a bit of the road feel.
The 19.5s will always be a little stiff. My experience with them is limited to work vehicles though, probably aired to the max.
Which poses the question, are you running them rock hard, max psi? Maybe more than needed for the load?
19.5s are recommended to run 70psi min (to keep the beads on the rims). You may get some more cushion at a lower pressure than you're running and still have adequate load capacity.
Financially speaking, there's not a better time to sell a vehicle, although no advantage considering the inflated costs of purchasing another to replace it.
