Grit_dog
Aug 04, 2022Trailblazer
markowwes wrote:Grit dog wrote:SoonDockin wrote:
The F450 is super capable. Maybe I should look for different tires to absorb a bit of the road feel.
The 19.5s will always be a little stiff. My experience with them is limited to work vehicles though, probably aired to the max.
Which poses the question, are you running them rock hard, max psi? Maybe more than needed for the load?
19.5s are recommended to run 70psi min (to keep the beads on the rims). You may get some more cushion at a lower pressure than you're running and still have adequate load capacity.
Financially speaking, there's not a better time to sell a vehicle, although no advantage considering the inflated costs of purchasing another to replace it.
You may want to watch what you do with your tire pressures, manufacturer says so much psi. to a certain weight but nothing about lighter loads. Lowering too much will cause heat and abnormal wear. You can try a different tire for your load and or contact the manufacturer and ask about what pressure for your load range. I run about 5 psi less than manufacturer suggested because the camper is not on all the time. I have approx. 32,000 mi. on factory tires with no sign of abnormal wear, which is not much but that is at an average 70 to 75 mph. any tire will wear faster at higher speeds. Stay away from the aggressive grip patterns unless you do a lot of off roading, they will be much quieter on the highways.
What part of 70psi min did you miss?
