Grit_dog
Aug 06, 2022Trailblazer
Cliff and Michele wrote:
As for tires and wheels, we are replacing our 19.5” tires with 20” wheels from Stazworks and Falken tires. Much better ride and you can air down the Falken’s to get through mud or snow or sand. You cannot do that with 19.5” tires.
So your replacing med duty G rated tires with custom wheels that allow you to run light duty E load tires? Presumably with a srw wide front rim and tire so as not to lose front capacity and essentially be “at” max load on the front of a class V diesel, at least, I hope?
Well this is a solution, but the thinking is flawed. You’re sacrificing tire life and capacity for presumably the very reason you bought the truck. To carry very heavy loads.
I guess if your primary objective is to have an “off road” rig that weighs like 8 tons, then it makes sense. But at that point, I’d do it right and mod ‘er up to take some big super singles.
But thanks for supporting a local Northern WI business. The depressed economy up there can use all the money it can get.
