Cliff_and_Miche
Aug 13, 2022Explorer
Grit dog wrote:Cliff and Michele wrote:
As for tires and wheels, we are replacing our 19.5” tires with 20” wheels from Stazworks and Falken tires. Much better ride and you can air down the Falken’s to get through mud or snow or sand. You cannot do that with 19.5” tires.
So your replacing med duty G rated tires with custom wheels that allow you to run light duty E load tires? Presumably with a srw wide front rim and tire so as not to lose front capacity and essentially be “at” max load on the front of a class V diesel, at least, I hope?
Well this is a solution, but the thinking is flawed. You’re sacrificing tire life and capacity for presumably the very reason you bought the truck. To carry very heavy loads.
I guess if your primary objective is to have an “off road” rig that weighs like 8 tons, then it makes sense. But at that point, I’d do it right and mod ‘er up to take some big super singles.
But thanks for supporting a local Northern WI business. The depressed economy up there can use all the money it can get.
I am replacing the rear tires with 20” wheels and tires for several reasons. First, better ground clearance when on BLM or NF roads. Second, I can air down as needed for sand and mud and snow. You cannot with the 19.5’s. The tires I am looking at are only 200 pound less capacity than the factory tires I have, still well within my needed capacity. And finally, a much better (I hope and have been told) ride. I am not a fan of super singles, having owned dump trucks and trailers.
I also intend to add the Liquid Spring system for the ride capacity and they just announced the ability to auto level the truck and camper at the end of the day. I am sold! And John at Stazworks sounds like a super good guy. Family business
I’m still waiting for my 20” wheels made from surplus MRAP vehicles. I will report back when I get them. I will post pictures when I get it all done.
