ChooChooMan74
Aug 04, 2016Explorer
You can use a tire inflation chart. Estimate what your truck weights empty, and go from there. For your size tire, this is what it says (note, all charts are an industry standard)
LT245/75R17 Single
35 PSI = 1770 Lbs
40 PSI = 1945 Lbs
45 PSI = 2110 Lbs
50 PSI = 2270 Lbs
55 PSI = 2430 Lbs
60 PSI = 2580 Lbs
65 PSI = 2755 Lbs
70 PSI = 2875 Lbs
75 PSI = 3020 Lbs
80 PSI = 3195 Lbs
LT245/75R17 Dual
35 PSI = 1610 Lbs
40 PSI = 1770 Lbs
45 PSI = 1920 Lbs
50 PSI = 2040 Lbs
55 PSI = 2210 Lbs
60 PSI = 2350 Lbs
65 PSI = 2535 Lbs
70 PSI = 2615 Lbs
75 PSI = 2750 Lbs
80 PSI = 2910 Lbs
LT245/75R17 Single
35 PSI = 1770 Lbs
40 PSI = 1945 Lbs
45 PSI = 2110 Lbs
50 PSI = 2270 Lbs
55 PSI = 2430 Lbs
60 PSI = 2580 Lbs
65 PSI = 2755 Lbs
70 PSI = 2875 Lbs
75 PSI = 3020 Lbs
80 PSI = 3195 Lbs
LT245/75R17 Dual
35 PSI = 1610 Lbs
40 PSI = 1770 Lbs
45 PSI = 1920 Lbs
50 PSI = 2040 Lbs
55 PSI = 2210 Lbs
60 PSI = 2350 Lbs
65 PSI = 2535 Lbs
70 PSI = 2615 Lbs
75 PSI = 2750 Lbs
80 PSI = 2910 Lbs
44,056 PostsLatest Activity: May 04, 2014
