dallaire's avatar
dallaire
Mitsubichi outlander V6
Anyone pulling a TT 3000 lbs with a Mitsubichi Outlander V6 automatic
  • No way. The outlanders are cars. Twenty years ago I had a lifted 4cyl Mitsubishi montero sport mud pit and rock crawling setup. 200% tougher than modern Mitsubishi
  • 3500 lbs towing with the V6 and it can hold 7 passengers... though not at the same time.
    Why can't the suspension handle towing?
    Maybe not a monster travel trailer but up to its ratings... no problem.
    Thanks!
    Jereimah
  • RinconVTR wrote:
    If you can or would pull it with a mini-van, you can pull it with the Outlander.
    And you know this how...?
  • If you can or would pull it with a mini-van, you can pull it with the Outlander.
    Nope, and don't even try. The suspension is not up to the task of towing anything. I own one and have worked on the suspension.
