jus2shy
Oct 07, 2015Explorer
phipps33 wrote:
One more question, 2 of my tires require 35psi and 2 require 50psi. I'm guessing this means different load ranges. If they are different load ranges, should each load range be on the same axle?
Sorry for the questions, I'm trying to learn as much as I can.
Thanks!
There should be a numerical number noting the "Service Load Index" of the tire. Typically it's a number between 80 and 130. If you have different service load index values, then your tires aren't rated to carry the same load. The pressure thing could be an indicator of that very issue.
44,057 PostsLatest Activity: Mar 12, 2026
