AH_AK wrote:
Grit dog wrote:
Ya, no inherent issues slicing and dicing a flatbed for your needs.
Also not a huge deal to have a cog a little aft of the rear axle on such a big truck….except they already ride horribly and adding weight to the FA helps that.
A 4500-5500 never rides good unless there’s a snowplow hanging off the front!
I thought you already had the truck. I’d think it much easier and more advantages than drawbacks to having a folding “deck” on the back of the flatbed.
You’d still have to get a camper all the way onto the bed. Or at least no vertical overhang in the rear.  But a folding deck has some advantages. Can build it relatively lightweight. Can remove it easily for other truck duties.  It’s up and out of the way while traveling and most importantly not getting covered with mud driving around the great state of AK.  Also you could build it fairly long for a huge deck if you wanted. Although length = weight.
Downside is having to drop it down to access the camper every time unless you can get maybe 2’ of flatbed overhang past the camper.
Thanks for the info on the 4500/5500 ride. I kind of suspected the ride quality would be the primary tradeoff in stepping up to the larger trucks. The fold out landing would definitely be sweet, but would require a bit more thought and design work. Definitely doable if you have the extra GVWR to play with. I have a modified 1T SRW right now, so I have to weigh any truck swap with the cost differential and hassle. I am 1000 lb over my GVWR so I am hesitant to add more weight. I have been on the prowl for a DRW 1T or f-450, but the market right now is nuts. Zero deals to be had. C&C’s with flatbeds are all over the place and reasonably priced.
As long as you own a kidney belt you’ll be fine!
Seriously though, they are a better value for gvw than a 1 ton.
Now I’ll tell you the real reason there are a ton of used ones for sale cheap in AK.
They’re ex Slope trucks. All of ‘em. Being from AK you should know this.
The smaller trucks are more marketable and cheaper to ship down to the L48 so more of them get a boat ride vs the med duty trucks.
And anything used on the slope will have 10,000s of hours on it. Maybe on its 2nd or 3rd engine (or 6th or 9th if it’s an old 6.0 Flowerjoke). Upside is they’re cheap and generally relatively well maintained if they came from a bigger outfit. And N slope rigs are far better to buy than oil sands rigs out of Alberta.
Another concern is tires, snow traction and tire cost. You’ll have 19.5s which are expensive and can’t be aired down to bust those drifts over Hatcher’s….imo the biggest negative about a med duty. That said you can get good mud grips and/or sipe them and have decent snow tires.
And like I said previously if you get some of that camper weight forward of the rear axle it will improve the ride noticeably.
