swimmer_spe wrote:
I have a 75 Terry TT.
Right now, the drains drain to the holding tank and then out. I am not using the holding tank now. I do not want to use it ever.
I plan to remove the bathroom fixtures. I want to run the kitchen sink into the ground.
So, to do this: Can I just cut the pipe going to the tank and direct it into the ground? The other drains have vents. Can I just cap the pipes at the roof, or must I remove it and repair the roof?
The trailer will not be moved anywhere anytime soon and there is no issue with grey water going directly to the ground.
What is the difference of emptying your gray into your gray tank vs emptying directly to the ground? You can still empty your gray from the tank. What happens if you ever decide to take the trailer on the road in the future. I guess I just understand the advantages to your plan????
