djgarcia wrote:
2012Coleman wrote:
I can't imagine living in a TT where the gray water is just dumped to the ground underneath it. That's going to be some cesspool after a while. Good luck with it.
X1, gray water dumped on the ground under the trailer will end up stinking and creating bad orders inside your trailer! If you are determined to dump gray water under the trailer, then strongly suggest you drain into a pipe i.e. PVC which dumps at least 20' away from the trailer, like a leach line in effect.
I was planning on digging down a good 2 -3 feet and have a holey pipe that the sink drains into.
