rexlion
Jul 05, 2014Explorer
I was certain that I posted a reply last night, but it seems to have vanished. Trying again...
I owned a Burro trailer for a couple of years. I think the big rv companies may not see the molded trailers as a good fit for their relatively rapid assembly line production methods.
A molded body does not have nearly so many linear feet of potential leak points as a conventional stick-built unit has. Eliminating the seams between roof and walls still leaves the windows, doors, vents, and plumbing to leak, nevertheless that is a big reduction in eventual leak risk.
If a stick built body leaks, one can quickly get mold or rot inside the walls, delamination, etc. If a molded fiberglass unit leaks at a window seam or something, one gets wet cushions. (But if left untreated for years, floor rot can still develop in some brands, if the water stands for too long.)
