travelnutz wrote:
valhalla360,
Apparantly you have never seen how the Egg Camper is made as there are 24 hours in a day and over night is dead time anyway. All molded fiberglass components that are done in a mold require curing time so there's very little additional time lost. Even at 50 weeks of five 8 hour days alone per week, there could easily be 250 total trailer bodies molded. Molded travel trailer manufacturers are very small companies and 250 trailers/year would be "big" to them.
As for the roof holes molded in areas, that's not an issue at all as it's only and 22' max trailer from the molds and the roof thru holes will still be in the same places. I take it that you don't understand spreading inserts in non pressure mold forms, The ends are spread and an insert is put in the mold to add to the length of the end to end length of the molded one piece side. The Egg Camper is 7' 4" wide unlike the 6' 5" of most other molded trailers.
Also very important is the true rounded lower air resistance front surface and the rear surface also that will not suck backward like a square or flat rear surface and therefore, will require a lot less engine power at highway speeds and result in increased MPG's. I do not own an Egg Camper or have anything to do with the company but I sure do understand air resistance created from moving the frontal flatter surface and the sucking action created from having a flatter back surface when traveling at highway speeds. A 6.5' X 6.5' surface for example, takes a lot of energy to push it thru the wind at 60 mph and then the same size rear sucking backward force as the air fights to return to fill the voided area where the trailer was. Aerodynamics 101!
No I've seen them.
Night isn't dead time at most factories. That's when the night shift comes in. So sitting in the mold curing is lost time.
Yes, I do understand extending fiberglass constructions and the seams are problem areas.
As long as you are willing to give up flexibility, the roof piercings won't move but it creates very limited options for producing more than 1 model and they appear very dated because they look pretty much the same as 40yr old units which isn't good for new sales (short sighted for buyers but true).
Rounded sounds nice but you will be hard pressed to notice the difference pulling a traditional trailer of similar size. It's just not a big issue beyond the theory of saving MPG.
