Rbertalotto
Aug 19, 2016Explorer
Here's one for you. I spoke to a "suspension engineer" and he suggested that I remove all the leafs but the main one and then add air bags between frame and axle. Let the airbag carry the trailer weight and not the spring. The single leaf spring would now be just to locate the axle.
It was suggested if the trailer doesn't lower down enough, to heat the spring to remove temper. He offered that to level a trailer you can raise the low side AND lower the high side to give you much more range of level.....
Interesting!
Interesting!
