Old-Biscuit
Oct 13, 2016Explorer III
myredracer wrote:
Have had our current TT for 2 1/2 years and it has seen 3 seasons of use. There's been quite a few ongoing problems to fix since we've had it, some minor and some serious. Just when I thought I'm about done finding things, I found a couple more yesterday. Pffft....
First pic is a piece of 2x3 under the bed for support. It's dropped 2+ inches at one end due to NO staples or fasteners holding it in place. Not hard to fix, but I have better things to do. I hate OSB in a TT and would re & re it with plywood but it goes under the closet and nightstand either side of the bed. Will probably add additional support pieces.
I pulled a fender skirt off yesterday to recaulk it (more poor workmanship and design) and noticed a ground wire above a tire. It's only about an inch from the tire and has been hitting and rubbing it. You can't see from the angle in the 2nd pic but the insulation is worn through. Easy fix on this one. Oh, and the rust in the pic - I have a lot of paint touchup to do throughout the frame due to being delivered in the winter and salt plus substandard painting at the frame manufacturer.
Someone asked about manufacturer's quality yesterday. It takes just as long to do things correctly as incorrectly as in these couple of examples and on many, many other things. When are they ever going to improve?
Things done incorrectly are achieved much quicker then doing it correctly the first time...........
PIECE MILL WORK!!
44,056 PostsLatest Activity: Jan 12, 2020
