Oasisbob
Dec 09, 2019Explorer
MOTOR OIL ?
After learning a certain oil change facility does not always change the oil filter when doing an oil change I went back to doing it myself. Things have changed on the motor oil shelf. So many choice...
harmanrk wrote:JRscooby wrote:
Not to say anything about the oil, but a 5 gallon bucket of oil? I change mine every 3 months and it takes 5 qts. That means from the time I open the jug until I put the last in the engine is 9 months. And another 3 months I'm expecting it to protect my engine. (For a while I would buy a 55 gal drum, leave drum in pickup, put a MT in with it. Could back up to a truck, pump new oil in the engine. Dump drain pans into the MT, and never need to move a full barrel.)
I five gallon bucket of oil is not at all out of the question. Modern Diesels in the larger pickups are 13 quarts (+/-). That's over 3 gallons per change. Also keeps in mind there are markets for oil in tractors and heavy trucks where 5 gallons is not a complete change.
Grit dog wrote:
So what’s the point Scooby? You buy 55gal drums of oil for your (old) gasser every 3 months because you either put on a lot of miles or have OOCCD , obsessive oil change compulsive disorder. (Likely since you through in the snippet about temperature matching the plug to the pan, lol)
But somehow this downplays someone who’s attempting to help by posting a good deal on oil in bulk?
Just cause you’re used to semis, hardly no one else buys drums of oil for personal use.
So why the negativity?
harmanrk wrote:
As for oil place horror stories, mine is pretty straightforward. Lived in an apartment for a while and could not change my own so had to use a quick lube. Bought a house, and on the first time changing the oil in my garage, had a the threads from the Aluminum pan attached to the steel plug. I'm not saying the tech (pimple faced highschooler) in the pit CAN'T do it right, just as other have said, at 8 buck an hour, they don't care about my car, as much as I do.
