CAJW
Feb 16, 2017Explorer
I carry my dirt bike on a carrier plugged into my Torklift 32" Superhitch extension. I'd contacted Torklift to clarify the tongue weight ratings, figured the arm, multiplied the weight and still have a healthy margin for safety. The one thing I didn't like was the side to side rocking of the carrier, so I rigged up some coated 1/4" cable with sailboat quick release adjustable turnbuckles to semi-support the carrier. I attached the upper ends to the camper jack mount bolts and the lower ends to the carrier rail. Works well and I'm sure that if I wanted, I could add a bicycle carrier to the mix.
As a side note to the OP, is it an optical illusion in the third picture of your post or is your Arctic Fox camper setting a bit tail low?
